LBZ UP PIPE CRACKED
2.2K views 8 replies 6 participants last post by  DMAXfirefighter
Good day y'all, looking for up pipe replacement suggestions for my LBZ...???? help....
Are you just wanting stock replacement? Or do you want something better quality that won't crack as easily again..
#4 ·
Best price I've seen, make sure they will fit lbz before you buy them but I think they will.
I agree with the last two statements- if you're just needing to replace the broken one because the bellow for the egr riser broke, just get an LB7 up pipe. Or you could just take you broken one off, cut the riser off and weld a piece over that opening. I have a good friend that can weld stainless and that's what we've done several times. But an LB7 up pipe would be sufficient
