How many miles on your LLY?
1 reading
47K views 118 replies 91 participants last post by  pmulls870
Im from Canada so everything is in kms, but how many miles/kms do you guys have on your lly's? What all have you had to do repair wise?
I have 312000km on mine now, that's 193000 miles or so, no issues other than it has started the pump rub pin hole. also Canadian truck
#4 ·
Good to hear about some higher milers!!! I might have an 2005 in the cards in the next couple months that I may purchase from my dad. Hes the original owner, and it will be running around 220-230k. Just wanted to hear some other peoples experiences.
I got 240K miles on my 05, gonna need a built trans in near future but thats my fault not the trucks:D
100,700 miles so far and no issues whatsoever..!
#11 ·
95k miles. One injector (way positive). Front wheel bearings, drive-line carrier bearing (two-piece drive line).
#12 ·
80k miles, have only had to replace the glow plug control module and 8 glow plugs, been a great truck
#14 ·
Almost 150k. Had four injectors at 77k one front wheel bearing, and front diff rebuilt before I got it. I had to put new bearings and seals in the front diff, assuming it wasn't done right before I got it. Also did the other front wheel bearing. I think most of the front end problems were due to it being cranked way up.
Oh yeah, need to change a wheel stud soon also. Cross threaded lug nut will do that.
#16 ·
290,000kms a few minor things in the front end, a glow plug, and a lot of preventative stuff.
#20 ·
I have 150,000 mile. I've had wheel bearing, wiring harness, fuel filter housing, A/C relay, dash cluster, water pump and most recently a stuck turbo. And have a feeling I have some front end parts to replace - still on original brakes oddly enough. A little less than thrilled with what I thought I was getting.
#24 ·
#26 ·
