Fass 150 Installation
10K views 16 replies 11 participants last post by  Mattb2179
I finally did the delete on my truck and left the converter - holy guac! It's a completely different truck. I need to install a lift pump now and was going to do the Fass 150.
For a guy that has some mechanical means, how difficult is it to install? One place quoted me $400. That seems kind of steep by reading on here that it's about a 2 hour job. I am by no means a mechanic, but if it can be done with simple garage tools (nothing special), I'm in.
I just did mine not long ago. It is super easy to install. If you have any mech. skills you will be just fine. Save the $$ and do it yourself.
You should have no problem as long as you know what a wrench is. :) Just be careful with the fuel line clips. Ask me how I know.
I second on the fuel clamps. If your break the connector tube the the in-tank basket, be ready to drop the tank and another $360 for a new basket. The install overall is easy and straight forward. It's easier to get to those clamps with the exhaust out, so hopefully you are in the process of doing that.
#8 · (Edited)
Damn 400 sounds steep to me. It was 20 degrees here and I don't have a garage so I took mine to a friends shop. 400 bucks, did my exhaust, down pipe, lift pump, inspection through 2016:D
The parts sat in my house for 2 weeks I couldn't wait for warmer weather haha
#12 ·
I installed my Fass titainium 150 on the ground as well. Like everyone says hardest part is that fuel line disconnect, I fought with mine for awhile before I got it.
#15 ·
I don't know, I haven't been under there to scout it out yet, but if that's the line I need to disconnect for a lift pump, then yes.
