swapped my 01 cab with a 03 cab, swapped the front end fuse box everything that goes with the 03 except for the engine, harness (from fuse box to ecm,tcm and over to engine), now i traced down the wiring from alldata and found out that the 03 model uses the ecm to trigger the starter and a few funtions for the a/c to work properly.
does my 01 ecm/tcm function the same as the 03?
do i just need to re-program the ecm/tcm?
or do i have to pick up a new ecm/tcm for the 03?
any insight is much needed here. i miss my truck it has been down since april when the guy stole it and wrecked itfuck.
thank you chris
thank you chris
